tau ga modem apa aja yg support sm gammu...
saya udah coba e173 tp ga bs...padahal di situs gammu-y bisa...
saya pakek prolink seri phs101 lancar aja
London Ky Thompson Drugs , Studies show that Zithromax is very effective in many cases of bacterial diseases and will work well as long as it's used according to the specified instructions. You should not use Zithromax when you have liver problems or jaundice, and if you're allergic to the ingredients in this drug. azithromycin without prescription You should not use Zithromax when you have liver problems or jaundice, and if you're allergic to the ingredients in this drug. It can also be used in children, where it can help with middle ear infections, pneumonia, and tonsillitis.
Lortab Pain Medication , There are some side effects that can be caused by Zithromax, and this drug should not be taken along with some other medications. Even if your symptoms are cured before the end of your prescription period, you should always finish your dosage until the end. buy azithromycin no prescription Many types of bacteria based diseases can be treated by this medication, such as respiratory infections, skin infections, ear infections, and sexually transmitted diseases. They are often pink and coated with a film like substance.
