Topic: Squid Manipulasi Bandwidth dan Cache Game Online dan Video Youtube
Numpang Lewat Agan2
Script Squid ane seperti ini :
http_port 3128 transparent
server_http11 on
pid_filename /var/run/squid.pid
coredump_dir /var/spool/squid/
error_directory /usr/share/squid/errors/English
icon_directory /usr/share/squid/icons
mime_table /usr/share/squid/mime.conf
visible_hostname AZKA FAIRUZ
cache_mgr [email protected]
access_log /var/log/squid/access.log
cache_log /var/log/squid/cache.log
cache_store_log /dev/null
log_fqdn off
log_icp_queries off
buffered_logs off
emulate_httpd_log off
acl localnet src 192.168.0.0/24
uri_whitespace strip
dns_testnames 127.0.0.1
dns_nameservers 127.0.0.1
cache_mem 32 MB
maximum_object_size_in_memory 204800 KB
memory_replacement_policy heap GDSF
cache_replacement_policy heap LFUDA
cache_dir aufs /cache1 20000 64 256
cache_dir aufs /cache2 23000 64 256
maximum_object_size 256000 KB
offline_mode off
cache_swap_low 98
cache_swap_high 99
acl all src 0.0.0.0/0
acl localhost src 127.0.0.1/32
acl safeports port 21 70 80 81 210 280 443 488 563 591 631 777 901 3128 1025-65535
acl sslports port 443 563 81
acl manager proto cache_object
acl purge method PURGE
acl connect method CONNECT
acl dynamic urlpath_regex cgi-bin \?
acl youtube dstdomain .youtube.com
acl speedtest dstdomain .speedtest.net
acl speedtest_allow_url url_regex -i \.speedtest\.net\/ speedtest
acl speedtest_allow_url url_regex ^http:\/\/speedtest\.*
acl speedtest_allow_dom dstdomain .speedtest.net
storeurl_access allow speedtest_allow_url
storeurl_access allow speedtest_allow_dom
refresh_pattern speedtest.*\.(jp(e?g|e|2)|tiff?|bmp|gif|png|swf|tx t|js) 0 50% 180 override-expire store-stale negative-ttl=0
cache allow youtube
cache allow speedtest
http_access allow manager localhost
http_access deny manager
http_access allow purge localhost
http_access deny purge
http_access deny !safeports
http_access deny CONNECT !sslports
http_access allow localhost
http_access allow localnet
http_access deny all
snmp_port 3401
acl snmppublic snmp_community public
snmp_access allow snmppublic all
acl store_rewrite_list urlpath_regex \/(get_video|videoplayback\?id|videoplayback.*id) \.(jp(e?g|e|2)|gif|png|tiff?|bmp|ico|flv|wmv|3gp|m p(4|3)|exe|msi|zip|on2|mar|swf)\?
acl store_rewrite_list_domain url_regex ^http:\/\/([a-zA-Z-]+[0-9-]+)\.[A-Za-z]*\.[A-Za-z]*
acl store_rewrite_list_domain url_regex (([a-z]{1,2}[0-9]{1,3})|([0-9]{1,3}[a-z]{1,2}))\.[a-z]*[0-9]?\.[a-z]{3}
acl store_rewrite_list_path urlpath_regex \.(jp(e?g|e|2)|gif|png|tiff?|bmp|ico|flv|avc|zip|m p3|3gp|rar|on2|mar|exe)$
acl store_rewrite_list_domain_CDN url_regex (khm|mt)[0-9]?.google.co(m|\.id) streamate.doublepimp.com.*\.js\? photos-[a-z].ak.fbcdn.net \.rapidshare\.com.*\/[0-9]*\/.*\/[^\/]* ^http:\/\/(www\.ziddu\.com.*\.[^\/]{3,4})\/(.*) \.doubleclick\.net.* yieldmanager cpxinteractive ^http:\/\/[.a-z0-9]*\.photobucket\.com.*\.[a-z]{3}$ quantserve\.com
acl dontrewrite url_regex yimg.com redbot\.org (get_video|videoplayback\?id|videoplayback.*id).*b egin\=[1-9][0-9]* \.php\?
acl getmethod method GET
storeurl_access deny dontrewrite
storeurl_access deny !getmethod
storeurl_access allow store_rewrite_list_domain_CDN
storeurl_access allow store_rewrite_list_domain store_rewrite_list_path
storeurl_access deny all
storeurl_rewrite_program /etc/squid/storeurl.pl
storeurl_rewrite_children 7
storeurl_rewrite_concurrency 60
storeurl_bypass on
hierarchy_stoplist (ini|ui|lst|inf||mh-|sc-)$ (afs.dat|update.txt|vdf.info.gz|captcha|reset.css| gamenotice|ickernew.css)
acl QUERY urlpath_regex -i \.(ini|ui|lst|inf|mh-|sc-)$
acl QUERY urlpath_regex -i (afs.dat|captcha|reset.css|update.txt|gamenotice|v df.info.gz)
cache deny QUERY
# TAG: Refresh Pattern
# 1 year = 525600 mins, 1 month = 43200 mins, 1 day = 1440
refresh_pattern (get_video\?|videoplayback\?|videodownload\?|\.flv ?) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-private override-expire override-lastmod reload-into-ims store-stale
refresh_pattern (get_video\?|videoplayback\?id|videoplayback.*id|v ideodownload\?|\.flv?) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-private override-expire override-lastmod reload-into-ims store-stale
refresh_pattern \.(ico|video-stats) 1440 90% 43200 override-expire ignore-reload ignore-no-cache ignore-no-store ignore-private ignore-auth override-lastmod ignore-must-revalidate negative-ttl=10080 store-stale
refresh_pattern \.etology\? 1440 90% 43200 override-expire ignore-reload ignore-no-cache store-stale
refresh_pattern galleries\.video(\?|sz) 1440 90% 43200 override-expire ignore-reload ignore-no-cache store-stale
refresh_pattern brazzers\? 1440 90% 43200 override-expire ignore-reload ignore-no-cache store-stale
refresh_pattern \.adtology\? 1440 90% 43200 override-expire ignore-reload ignore-no-cache store-stale
refresh_pattern ^.*(utm\.gif|ads\?|rmxads\.com|ad\.z5x\.net|bh\.co ntextweb\.com|bstats\.adbrite\.com|a1\.interclick\ .com|ad\.trafficmp\.com|ads\.cubics\.com|ad\.xtend media\.com|\.googlesyndication\.com|advertising\.c om|yieldmanager|game-advertising\.com|pixel\.quantserve\.com|adperium\. com|doubleclick\.net|adserving\.cpxinteractive\.co m|syndication\.com|media.fastclick.net).* 43200 20% 43200 ignore-no-cache ignore-no-store ignore-private override-expire ignore-reload ignore-auth ignore-must-revalidate store-stale negative-ttl=40320 max-stale=10
refresh_pattern ^.*safebrowsing.*google 1440 90% 43200 override-expire ignore-reload ignore-no-cache ignore-private ignore-auth ignore-must-revalidate negative-ttl=10080 store-stale
refresh_pattern ^http://((cbk|mt|khm|mlt)[0-9]?)\.google\.co(m|\.uk) 1440 90% 43200 override-expire ignore-reload ignore-private store-stale negative-ttl=10080
refresh_pattern ytimg\.com.*\.jpg 1440 90% 43200 override-expire ignore-reload store-stale
refresh_pattern images\.friendster\.com.*\.(png|gif) 1440 90% 43200 override-expire ignore-reload store-stale
refresh_pattern garena\.com 1440 90% 43200 override-expire reload-into-ims store-stale
refresh_pattern photobucket.*\.(jp(e?g|e|2)|tiff?|bmp|gif|png) 1440 90% 43200 override-expire ignore-reload store-stale
refresh_pattern vid\.akm\.dailymotion\.com.*\.on2\? 1440 90% 43200 ignore-no-cache override-expire override-lastmod store-stale
refresh_pattern mediafire.com\/images.*\.(jp(e?g|e|2)|tiff?|bmp|gif|png) 1440 90% 43200 reload-into-ims override-expire ignore-private store-stale
refresh_pattern ^http:\/\/images|pics|thumbs[0-9]\. 1440 90% 43200 reload-into-ims ignore-no-cache ignore-no-store ignore-reload override-expire store-stale
refresh_pattern ^http:\/\/www.onemanga.com.*\/ 1440 90% 43200 reload-into-ims ignore-no-cache ignore-no-store ignore-reload override-expire store-stale
refresh_pattern ^http://v\.okezone\.com/get_video\/([a-zA-Z0-9]) 1440 90% 43200 override-expire ignore-reload ignore-no-cache ignore-no-store ignore-private ignore-auth override-lastmod ignore-must-revalidate negative-ttl=10080 store-stale
# ANTI VIRUS
refresh_pattern guru.avg.com/.*\.(bin) 1440 90% 10080 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern (avgate|avira).*(idx|gz)$ 1440 90% 10080 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern kaspersky.*\.avc$ 1440 90% 10080 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern kaspersky 1440 90% 10080 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern update.nai.com/.*\.(gem|zip|mcs) 1440 90% 10080 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern ^http:\/\/liveupdate.symantecliveupdate.com.*\(zip) 1440 90% 10080 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern windowsupdate.com/.*\.(cab|exe) 10080 90% 43200 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern update.microsoft.com/.*\.(cab|exe) 10080 90% 43200 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
refresh_pattern download.microsoft.com/.*\.(cab|exe) 10080 90% 43200 ignore-no-cache ignore-no-store ignore-reload reload-into-ims store-stale
#images facebook
refresh_pattern -i \.facebook.com.*\.(jpg|png|gif) 1440 90% 129600 ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern -i \.fbcdn.net.*\.(jpg|gif|png|swf|mp3) 1440 90% 129600 ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern static\.ak\.fbcdn\.net*\.(jpg|gif|png) 1440 90% 129600 ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern ^http:\/\/profile\.ak\.fbcdn.net*\.(jpg|gif|png) 1440 90% 129600 ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
# games facebook
refresh_pattern ^http:\/\/apps.facebook.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern -i \.zynga.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store ignore-must-revalidate store-stale
refresh_pattern -i \.farmville.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store ignore-must-revalidate store-stale
refresh_pattern -i \.ninjasaga.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store ignore-must-revalidate store-stale
refresh_pattern -i \.mafiawars.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store ignore-must-revalidate store-stale
refresh_pattern -i \.crowdstar.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store ignore-must-revalidate store-stale
refresh_pattern -i \.popcap.com.*\/ 10080 90% 43200 ignore-reload override-expire ignore-no-cache ignore-no-store ignore-must-revalidate store-stale
#banner IIX
refresh_pattern ^http:\/\/openx.*\.(jp(e?g|e|2)|gif|pn[pg]|swf|ico|css|tiff?) 1440 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern ^http:\/\/ads(1|2|3).kompas.com.*\/ 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern ^http:\/\/img.ads.kompas.com.*\/ 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern .kompasimages.com.*\.(jpg|gif|png|swf) 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern ^http:\/\/openx.kompas.com.*\/ 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern kaskus.\us.*\.(jp(e?g|e|2)|gif|png|swf) 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
refresh_pattern ^http:\/\/img.kaskus.us.*\.(jpg|gif|png|swf) 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale
#IIX DOWNLOAD
refresh_pattern ^http:\/\/\.www[0-9][0-9]\.indowebster\.com\/(.*)(mp3|rar|zip|flv|wmv|3gp|mp(4|3)|exe|msi|zip) 43200 90% 129600 reload-into-ims ignore-reload override-expire ignore-no-cache ignore-no-store store-stale ignore-auth
#All File
refresh_pattern -i \.(3gp|7z|ace|asx|bin|deb|divx|dvr-ms|ram|rpm|exe|inc|cab|qt) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-must-revalidate override-expire override-lastmod reload-into-ims store-stale
refresh_pattern -i \.(rar|jar|gz|tgz|bz2|iso|m1v|m2(v|p)|mo(d|v)|arj| lha|lzh|zip|tar) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-must-revalidate override-expire override-lastmod reload-into-ims store-stale
refresh_pattern -i \.(jp(e?g|e|2)|gif|pn[pg]|bm?|tiff?|ico|swf|dat|ad|txt|dll) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-must-revalidate override-expire override-lastmod reload-into-ims store-stale
refresh_pattern -i \.(avi|ac4|mp(e?g|a|e|1|2|3|4)|mk(a|v)|ms(i|u|p)|o g(x|v|a|g)|rm|r(a|p)m|snd|vob) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-must-revalidate override-expire override-lastmod reload-into-ims store-stale
refresh_pattern -i \.(pp(t?x)|s|t)|pdf|rtf|wax|wm(a|v)|wmx|wpl|cb(r|z |t)|xl(s?x)|do(c?x)|flv|x-flv) 1440 90% 43200 ignore-no-cache ignore-no-store ignore-must-revalidate override-expire override-lastmod reload-into-ims store-stale
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern ^ftp: 10080 95% 43200 override-lastmod reload-into-ims store-stale
refresh_pattern . 00 95% 43200 override-lastmod reload-into-ims store-stale
header_access X-Forwarded-For deny all
header_access Accept-Encoding deny all
client_persistent_connections off
server_persistent_connections on
half_closed_clients off
strip_query_terms off
quick_abort_min 0 KB
quick_abort_max 0 KB
quick_abort_pct 100
vary_ignore_expire on
reload_into_ims on
pipeline_prefetch on
shutdown_lifetime 10 seconds
read_timeout 30 minutes
client_lifetime 6 hours
negative_ttl 30 seconds
positive_dns_ttl 6 hours
negative_dns_ttl 60 seconds
pconn_timeout 15 seconds
request_timeout 1 minute
store_avg_object_size 13 KB
ipcache_size 4096
ipcache_low 98
ipcache_high 99
fqdncache_size 4096
memory_pools off
forwarded_for off
logfile_rotate 1
cache_effective_user proxy
cache_effective_group proxy
client_db on
max_filedescriptors 4096
n_aiops_threads 12
load_check_stopen on
load_check_stcreate on
download_fastest_client_speed on
zph_mode tos
zph_local 0x30
zph_parent 0
zph_option 136
bisa kah buat Squid Manipulasi Bandwidth dan Cache Game Online dan Video Youtube
Re: Squid Manipulasi Bandwidth dan Cache Game Online dan Video Youtube
bro vicky
ini dah oke ya? untuk squid di windows bisa ga?
Itu untuk squid 2.7 biasa kang tanpa lusca kan???
saya nyari yang tanpa lusca soalnya
