Pages: 1 2
untuk lebih mudah saya menggunakan 2 virtual server, yaitu :
1. IP Mikrotik:
- 192.168.10.15 = local
- 192.168.12.15 = proxy
- 192.168.5.181 = public/ke modem speedy
2. IP squid (pakai IPCop)
- 192.168.12.1 = ip green(procy)
3. IP Client: 192.168.10.0/24
ok di ipcop disetting dulu bahwa web proxynya jalan di port 878 <= terserah anda aktifkan cachenya misal 15M atau 15000 <= untuk testing
sekarang kita masuk ke mikrotiknya:
/ ip address
add address=192.168.5.181/24 network=192.168.5.0 broadcast=192.168.5.255 \
interface=Public comment="" disabled=no
add address=192.168.10.15/24 network=192.168.10.0 broadcast=192.168.10.255 \
interface=Lan comment="" disabled=no
add address=192.168.12.15/24 network=192.168.12.0 broadcast=192.168.12.255 \
interface=Proxy comment="" disabled=nosetting route:
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.5.15 scope=255 target-scope=10 \
comment="" disabled=nosetting dns:
/ ip dns
set primary-dns=192.168.5.182 secondary-dns=192.168.5.205 \
allow-remote-requests=no cache-size=2048KiB cache-max-ttl=1w
/ ip dns static
add name="192.168.5.3" address=192.168.5.3 ttl=1dsetting nat:
/ ip firewall nat
add chain=dstnat protocol=tcp dst-port=81 action=dst-nat \
to-addresses=192.168.12.1 to-ports=81 comment="Untuk IP Cop" disabled=no
add chain=dstnat protocol=tcp dst-port=445 action=dst-nat \
to-addresses=192.168.12.1 to-ports=445 comment="Untuk HTTPS IPCOP" \
disabled=no
add chain=dstnat src-address=!192.168.12.0/24 protocol=tcp dst-port=80 \
action=dst-nat to-addresses=192.168.12.1 to-ports=878 comment="" disabled=no
add chain=dstnat src-address=!192.168.12.0/24 protocol=tcp dst-port=443 \
action=dst-nat to-addresses=192.168.12.1 to-ports=878 comment="" \
disabled=no
add chain=srcnat out-interface=Public action=masquerade comment="" disabled=nonah terus ini yang paling penting, setting manggle:
/ ip firewall mangle
add chain=forward content="X-Cache: HIT" action=mark-connection \
new-connection-mark=squid_con passthrough=yes comment="" disabled=no
add chain=forward connection-mark=squid_con action=mark-packet \
new-packet-mark=squid_pkt passthrough=no comment="" disabled=no
add chain=forward connection-mark=!squid_con action=mark-connection \
new-connection-mark=all_con passthrough=yes comment="" disabled=no
add chain=forward protocol=tcp src-port=80 connection-mark=all_con \
action=mark-packet new-packet-mark=http_pkt passthrough=no comment="" \
disabled=no
add chain=forward protocol=icmp connection-mark=all_con action=mark-packet \
new-packet-mark=icmp_pkt passthrough=no comment="" disabled=no
add chain=forward protocol=tcp dst-port=1973 connection-mark=all_con \
action=mark-packet new-packet-mark=top_pkt passthrough=no comment="" \
disabled=no
add chain=forward connection-mark=all_con action=mark-packet \
new-packet-mark=test_pkt passthrough=no comment="" disabled=noterus queue :
/ queue simple
add name="Squid_HIT" dst-address=0.0.0.0/0 interface=all parent=none \
packet-marks=squid_pkt direction=both priority=8 \
queue=default-small/default-small limit-at=0/0 max-limit=0/0 \
total-queue=default-small disabled=no
add name="Main_Link" dst-address=0.0.0.0/0 interface=all parent=none \
direction=both priority=8 queue=default-small/default-small limit-at=0/0 \
max-limit=35000/256000 total-queue=default-small disabled=no
add name="game_tales_of_pirate" dst-address=0.0.0.0/0 interface=all \
parent=none packet-marks=top_pkt direction=both priority=1 \
add name="Ping_queue" dst-address=0.0.0.0/0 interface=all parent=none \
packet-marks=icmp_pkt direction=both priority=2 \
add name="The_other_port_queue" target-addresses=192.168.12.0/24 \
dst-address=0.0.0.0/0 interface=all parent=Main_Link packet-marks=http_pkt \
direction=both priority=8 queue=default-small/default-small \
limit-at=5000/5000 max-limit=50000/256000 total-queue=default-small \
disabled=no
add name="another_port" target-addresses=192.168.10.0/24 dst-address=0.0.0.0/0 \
interface=all parent=Main_Link packet-marks=test_pkt direction=both \
max-limit=0/256000 total-queue=default-small disabled=nohasilnya:
pertama mencache:
kedua hasil cachenya:
sorry ternyata ada yang salah dalam setting NAT, mmaf keliru paste, jadi ni aku kasih yang benar
mohon tanggapannya
kang Onno masukin ke wiki dong ini, penting banget nih
Gud Job Bro
saya lagi di samarinda sekarang ini
paling cepet hari selasa nih ..
kalau ada yang mau masukin ke wiki
silahkan lho
wiki kebuka buat semua orang ngedit koq
asal register username & password dulu ..
weew jauh kali
saya masih blum ngeti cara edit wikinya
jadi teman2 yg bisa edit masukin deh, rumayan tutor ini bwat blajar
Thx b4
Silahkan baca-baca
http://opensource.telkomspeedy.com/wiki … is_di_Wiki
Gak susah koq ngedit Wiki
sama rumit-nya dg ngedit Forum & ngedit Blog
Ok sudah di masukan ke Wiki silahkan di baca-baca di
http://opensource.telkomspeedy.com/wiki … ih_optimal
Ttg Mikrotik yang lain bisa di baca di
http://opensource.telkomspeedy.com/wiki … r_Mikrotik
makasih kang onno
akan saya pelajari cara editnya
makin banyak tutor di wiki makin banyak ilmu yg di dapat MUANTAF![]()
maaf sekalian, rencana awal mo aku masukin ke wiki, cuman karena saya pakai proxy kadang ngadat tu wiki-nya waktu masukking captha<=salah eja kali.
terima kasih kang onno
Captha hanya akan di tanya kalau kita masukin URL
kalau gak ada URL-nya sih biasanya gak akan tanya captha ..
aman-aman aja kalau tanpa URL
maklum spammer rada gelo sih ..
untuk setingan NAT nya saya salah paste, jadi mohon maaf ya. sudah saya edit
untuk dapetin program mikrotik-nya koq susah yg gratis, bentuk ISO CD-nya maksud-nya ISO CD seperti IPCop...
please, bagi2 Mikrotik dong....![]()
@opik
mikrotik itu program yang harus dibeli
jika yang gratis itu hanya untuk 24jam saja.
kalau yang versi crack cuman satu 2.9.27 coba saja cari di google, masukkan kata kunci 'mikrotik 2.9.27 crack'
kalo mo beli normal Rp. 400.000 di www.mikrotik.co.id
waaak ... !!! baru tau ane, ternyata fasilitas web-proxy yg ada di mikrotik itu juga pake squid. hmmm ... tapi kok confignya dikit amat ya
modem -- mikrotik -- local_network
proxy
la iyalah kan mikrotik itu linux hihihi ![]()
proxy di mikrotik kurang mantep ... makanya orang2 sering menggunakan proxy yang terpisah dari mikrotik.
makanya di atas juga sy tanya : *tapi kok confignya dikit amat ya*
setuju om ... kalo kata sinchan mah : proxy yang annneh.... ![]()
kalo versi 3 katanya lumayan, kita bisa tahu kapan suatu request kena hit apa tidak. dan bisa di mangle.
aku dah implementasikan langsung pakai internal proxynya dan memang bisa lebih bagus.
sedikit itu karena di persimple saja.
hanya settingan umum. hak akses, cache access, direct saja
AdeldiaN wrote:
kalo versi 3 katanya lumayan ...
om punya jamunya nda ??? ![]()
share dong,
sy dah cari" belum nemu juga nih
kalo pakai versi 2.9 bisa pake ini http://www.forummikrotik.com/tutorial/2 … 2-9-a.html
kalo versi 3 pake ini :
add chain=output action=mark-packet new-packet-mark=proxy-hit passthrough=no out-interface=LAN dscp=4 add chain=prerouting action=mark-connection new-connection-mark=conn-icmp passthrough=yes in-interface=LAN protocol=icmp add chain=prerouting action=mark-packet connection-mark=conn-icmp new-packet-mark=icmp-pkt passthrough=no add chain=prerouting action=mark-connection new-connection-mark=conn-all passthrough=yes in-interface=LAN commecnt="This for all paket" add chain=forward action=mark-paket connection-mark=conn-all new-packet-mark=all-pkt passthrough=no add chain=output action=mark-packet connection-mark=conn-all new-packet-mark=all-pkt passthrough=no
terus buat redirect port 80 ke proxy, bikin queue dengan urutan:
yang packet proxy-hit unlimited teratas
packet icmp no 2
terkahir packet all-paket paling bawah
semoga berhasil
hehe ... om adel, maksud jamu diatas itu crack-nya versi 3 ..
punya nda ??
, eh malah dikasih contekan lagi ... tapi gpp deh, seperti biasa contek dulu ah
crack v3 belum ada
mending beli kalo km pakai sebagai warnet atau bisnis...... (masak ngecrak terus)
ya udah gpp kalo nda ada
googling lagi aj ................
sampe mampus klo ada ![]()
beli aja murah kok, buat warnet lg gak ada pendapatan 1 hari udah ketutup
Dijamin HALAL ![]()
masa sih ... tunggu aj, namanya juga bikinan orang pasti ada aj salahnya ![]()
Dijamin HALAL
iya deh tar gw beli kalo cicilan mio gw lunas ....
payah beli mikrotik aja nggak mau kalo m$ jendela pasti dibela-belain, masih suka yang crack-crackan hihihii
Pages: 1 2
